The compressor will operate without the run capacitor, but will run less efficiently and may reduce the overall life of the unit. How much of a difference it will make is hard to tell, but if your compressor was designed to work with it, I would reconnect it to the starter
Originally Posted by: TechnicianBrian  The compressor will operate without the run capacitor, but will run less efficiently and may reduce the overall life of the unit. How much of a difference it will make is hard to tell, but if your compressor was designed to work with it, I would reconnect it to the starter Thank you for quick response. I've done exactly this. I'm not surprised why tech didn't reconnected run capacitor, if it could reduce life of the compressor.:cool: do you happened to know where i could find diagram for my refrigerator?
