dirt-tx
#1 Posted : Sunday, April 1, 2012 4:14:32 PM(UTC)
dirt-tx
We just replaced a circulating motor-Pump last week (PN W102394) and after running a few times the dishwasher just stopped based on the water left in the machine. Once we tried to started it back up, we noticed that it appeared no power to the control panel due the absence of the lights or any actions.
After reviewing the forum, I located the thermal fuse and found that is does not have any continuity; therefore it needs to be replaced. I was wondering if there is anything else that I need to check before replacing the fuse, ie fuse usually are for safety once something else goes wrong. Does anyone have any comments or thoughts on this before I order this part? Any other comments? They are all welcomed.
#2 Posted : Monday, April 2, 2012 1:48:17 AM(UTC)
I cannot find any info on the given model number.
Please check it.
You could check the resistance on parts that are powered motor, dispenser etc. but you will need the tech sheet to know what they should be.
These fuses do seem to blow all on there own.
Be sure to use the new harness that comes with the replacement fuse as this is an important update.
Note: I am not sure the replacement is the type that includes the new harness.
