Machine fills with water but won't agitate, spin or then drain. Screen code indicates overloaded, but does the same thing even when empty. Advice? Whirlpool Calypso
THIS FORUM IS DEAD!!!!!!! |
The code was Ld, which I thought was overload, but it is "long drain." I did the spin and drain test per the instructions and it did nothing but make a humming noise (like it does anytime I turn it on now.) It does have water in it.
Of course I can't do the "drain and recirculation test" so is there any way to know if it's the pump, the pump motor or the wiring harness?
Thanks, Bill
See page 15 in the tech sheet, Test #7 |
