Duffy
#1 Posted : Monday, March 16, 2009 10:25:26 AM(UTC)
Duffy
The control panel has a thin plastic cover (Console Insert) part # 3374804. It's cracked so I need to replace it. I need instructions on how to remove it. I tried to remove the inside of the door by removing the screws around the edge but something that I can not see in the middle of the door panel is holding the panel. I have a parts diagram but it does not help explain "how to" do this.
#2 Posted : Monday, March 16, 2009 5:38:11 PM(UTC)
Replacement parts for WHIRLPOOL DU920QWDQ0 | AppliancePartsPros.com
Here is a service manual
https://secured.whirlpoo...839a7fa85256a8e00510938/$FILE/4322430.pdf
See Page 31 in the Power Clean Manual (2nd manual)
Note I am not sure about the following.
Perhaps someone who is sure will add a post.
Looks like the panel is just a peal and stick.
Often the old one can be removed by softening the glue with a hair dryer.
Be sure to clean the surface with isopropyl alcohol.
You may have to use varsol or mineral spirits to get the glue residue off.
Just clean it finally with isopropyl as it does not leave a residue.
Duffy
#3 Posted : Tuesday, March 17, 2009 9:09:09 AM(UTC)
Duffy
I will try your suggestion. Also the service manual PDF you provided was just what I have been trying to find.
Thanks very much for the help!
