tunafever
#1 Posted : Monday, March 16, 2009 2:58:07 PM(UTC)
tunafever
The ice maker stopped working, and today I replaced the water filter. I pushed the water dispenser until I purged the air from the system. I do not believe that water is dispensing in the ice maker. Any and all help would be appreciated.
Thanks Wes
woodchuckie
#2 Posted : Monday, March 16, 2009 6:30:08 PM(UTC)
woodchuckie
If the water dispenser works, swap the wires on the water inlet valve on the back where the water supply come in. Then try the dispenser and water should go into the ice maker letting you know the valve and line are working. Swap the wires back and manually fill the ice mold or if it filled let it freeze and see it it will start cycling after it dumps the ice.
Is there a reset button for the filter change.
tunafever
#3 Posted : Monday, March 16, 2009 7:11:23 PM(UTC)
tunafever
Thank You for the information. I turned off the ice maker switch and pulled out the new water filter and reinserted the filter. I turned on the on button switch, and ice cubes are dropping in tray. I can only assume that this process allowed for a reset.
Wes
