gbdad10
#1 Posted : Saturday, March 31, 2012 3:35:25 PM(UTC)
gbdad10
Our washer drains ok but seems to spins slowly and the clothes are dripping wet when the cycle completes. Is this a clutch issue and can you tell me if replacing the clutch is a big job. I am pretty handy but have not worked on washers before.
sidfink43
#2 Posted : Monday, April 2, 2012 4:22:09 PM(UTC)
sidfink43
It is a clutch issue if the basket is not spinning fast enough, but it may also be a partial obstruction in an internal drain hose.
Replacing the clutch is a good DIY job, here is the part
Part number: AP3094537
and a link to the video that will show you how to get into the machine to do the job.
Check those hoses first.
gbdad10
#3 Posted : Wednesday, April 4, 2012 6:36:14 PM(UTC)
gbdad10
The hose was bent where it hooked to the washing machine. Thanks for your help. :)
sidfink43
#4 Posted : Thursday, April 5, 2012 3:48:47 AM(UTC)
sidfink43
Glad you found the problem, and thanks for the update. Good luck going forward!
Guest (4)
Clothes still wet after spin cycle (Washer Repair)
by Rheinking 4/30/2010 11:19:45 AM(UTC)
