velvet911
#1 Posted : Sunday, March 15, 2009 11:01:15 AM(UTC)
velvet911
You have been a member since:: 3/15/2009(UTC)
Works great in all cycles except it emmits a very loud noise when in the spin cycle. It does spin.
#2 Posted : Monday, March 16, 2009 2:32:58 AM(UTC)
If the noise comes from the spin basket, pull the basket out and look for something stuck in the tub.
velvet911
#3 Posted : Monday, March 16, 2009 11:26:47 AM(UTC)
velvet911
It no longer spins at all now. I can hear a spinning sound inside the cabinet. I've been told to check the motor coupler. Does that sound right to you?
#4 Posted : Tuesday, March 17, 2009 12:40:48 AM(UTC)
You now probably have a busted coupler plus something stuck in the spin basket. Go to www.applianceaid.com for take apart info.
velvet911
#5 Posted : Tuesday, March 17, 2009 7:46:45 AM(UTC)
velvet911
I completely took apart agitater/basket. Nothing was there. Same sound when I put it back together. It sounds almost like an unbalanced knocking but it doesn't jump around. I replaced the coupler that broke while running it with this noise and it now spins again but the noise is back. I'm assuming i'll just break the new coupler if I again let it run through the spin cycle.
