I ordered a new part from your co,the part is close to the same except the old one has threaded ports and the one you sent me had push ins. The part #for the old one is 2204358 and the one you sent is 2206123.Is this a suitable sub or a mistake. Thank you.
The same line without the fitting will push in and seal while you're holding the quick connect in.
the hoses are not the same size as the push ins or I would have done that.
Then that would definitely be some type of mistake.
So do I send the new back? or am I out of luck.
