Dryermang
#1 Posted : Sunday, March 15, 2009 10:14:13 PM(UTC)
Dryermang
My washer fills but will not stop the filling cycle it just keeps filling up and up and up
any ideas
we have tried changeing the fill selection to small loads and it just keeps filling
thanks
#2 Posted : Monday, March 16, 2009 5:51:03 AM(UTC)
Sounds like the water level control is shot.
Especially if turning the unit off or unplugging it stops the water flow.
This tells you that the water valves themselves are OK.
The way it works is, it is a pressure switch.
It has a tube that runs to the bottom of the tub.
Water rises in this tube as the washer fills, this increases the air pressure in the tube.
When the pressure reaches the set point a switch activates, this turns the water off and begins the agitate cycle.
So the problem is
1. The level control is shot. Get a tube with the same internal diameter, attach this to the level control. Start a wash, blow into the tube, you should be able to activate the switch (turn the water off) without blowing into the tube overly hard.
2. Something is blocking the end of the tube preventing the water from entering it. Undo the tube at the level control and blow into it.
3. The tube is leaking or not sealing at the level control. Inspect it for cracks, holes etc. Cut half an inch on the end and re-seat it to the control.
Dryermang
#3 Posted : Monday, March 16, 2009 6:49:56 AM(UTC)
Dryermang
thanks for that if that doesnt work then i can assume its the switch the sending tube is talking to is bad correct??
#4 Posted : Monday, March 16, 2009 12:19:24 PM(UTC)
Not quite sure what you mean. The switch is part of the level control.
You did not include a Model Number so I could not look for a wiring diagram.
Dryermang
#5 Posted : Tuesday, March 17, 2009 1:37:42 PM(UTC)
Dryermang
LT5000xsn2
how do I access the tube, to check it?
could it be the fill settting switch is bad?
thanks again for your time
buy you a pina colada when you come to hawaii!!!
#6 Posted : Wednesday, March 18, 2009 5:24:43 AM(UTC)
Here is your parts breakdown
Replacement parts for WHIRLPOOL LT5000XSW2 | AppliancePartsPros.com
One end is Item 10 in the Washer/dryer control section
Other end is Item 11 in Tub & basket section
Here is a manual which should help
https://secured.whirlpoo...309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf
And here is a decent wiring diagram, may not need it now but might come in handy in the future
https://www.servicematters.com/d...0Sheet%20-%203388366.pdf
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
Thin Twin Washer Dryer (General Talk)
by Theadore 8/21/2007 3:00:38 PM(UTC)
