mobrien1
#1 Posted : Monday, March 16, 2009 6:24:23 AM(UTC)
mobrien1
Even though I adjust dial controlls in frig it does not get any warmer. Both the frig and freezer are below freezing.. What do I do? Also I can't get the ice-maker to work. Is there something wrong with the thermostat?
woodchuckie
#2 Posted : Monday, March 16, 2009 8:20:14 AM(UTC)
woodchuckie
Turn the freezer temperature control to warmer and warmer to see if it clicks off and stops the compressor from running. If it doesn't except in the off position that will be your problem.
mobrien1
#3 Posted : Monday, March 16, 2009 12:58:42 PM(UTC)
mobrien1
Woodchuckie, Thanks for the info. I tested it and it will not shut off unless I turn it all the way off. Which part do I need to replace...is it that whole box with controlls and light?
mobrien1
#4 Posted : Monday, March 16, 2009 1:05:20 PM(UTC)
mobrien1
Do I need to replace the whole piece including the controls and the light? What is the part number and how do I get it?
woodchuckie
#5 Posted : Monday, March 16, 2009 7:09:11 PM(UTC)
woodchuckie
I believe part 27 is your thermostat. Knob and freezer control. That is the only part you should need. This diagram of your control parts may help with disassembly. Replacement parts for WHIRLPOOL GD5RHAXNB00 | AppliancePartsPros.com
