:rolleyes: can someone tell me what can be wrong with my dryer
If you take the back off the dryer, you will see a white thin part called a thermal fuse. It will have 2 wires coming to it. Take the 2 wires off, and put the terminal ends together, and put some tape around it, so it does not hit metal, and then plug the dryer back in and give it a try. If it works, do not run the dryer like that, this is for testing only. If it does not work, we need to know if the ignitor comes on. If not, it could be the ignitor or the flame sensor, which is mounted on the side of the flame tube. Tom ApplianceEducator.com
