Front right element dont work- larger element- I have changed elements around and they work, light comes on at switch but not getting to element- do I need to replace switch or something else. Thanks
Here are your parts.
If by "I have changed elements around and they work". You moved the element to another location and it worked but the element from that location did not work in the right front, then the odds are that it is the infinite switch.
Note: that this is a bit of a guess as it could also be a wiring problem or a problem with the elements receiver/receptacle. |
THIS FORUM IS DEAD!!!!!!! |
