I have a probelm with the dishwasher . While washing , the washing cycle will stop for no reason, Then i have to hit the button panel in order to continued the cycle, never finish the cycle. i'm trying to find what wrong with it,, is it the keypad or the mother boar or is it the close latch. Need help! Thanks,
Juan
Remove the bottom panel and take a look at the motor. It is clean looking. Does it look like it's bee leaking a little water around the motor or even on the floor?
The motor is fine, no water. We dissambled the keypad and the door latch. Tested two door switches (black), put back together and it is working for now. We still have to tap the keypad/top of door to activate it. If it happens again, what do we replace? The keypad, the mother board, or the latch? Thanks.
