Puckhw7
#1 Posted : Tuesday, March 27, 2012 8:06:43 PM(UTC)
Puckhw7
Electric range press bake set temp. @ 400 display shows bake on but temp drops to 100 can t adjust temp. then shuts off. broil does same thing set to high comes on then goes off. never get voltage to elements???
#2 Posted : Thursday, March 29, 2012 1:40:33 AM(UTC)
Replacement parts for JDP36GP models | AppliancePartsPros.com
It is a GE and they like to keep all tech info a secret so I cannot be of much help.
First try unplugging or flipping the breaker off/on to see if it will reset itself.
If this does nothing,I would check the oven sensor (Item 253 in Section 4) at the control board, just in case they are doing something weird if it gives the wrong resistance output.
Here is a link on how to do that.
http://www.applianceaid.com/elecrange.html
Take a look at 7, 8, 20 and 21.
Also check that the wiring from the control board to the elements is OK.
If both the above are OK then odds are that the control board is toast and it is no longer available.
Oven bake/broil not working after bake element replacement (Oven Repair (including Ranges and Cooktops))
by J Justin 11/5/2009 1:29:07 PM(UTC)
