w. carroll
#1 Posted : Wednesday, March 28, 2012 8:22:26 AM(UTC)
w. carroll
Just replaced the complete wiring harness and pigtail after dryer shorted out. dryer now gets hot when plugged in, but nothing works.
Simon / APP Team
#2 Posted : Wednesday, March 28, 2012 12:20:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Before going any further, make sure the harness is installed correctly.
Check the thermal fuse, if it's open the motor would not run.
With dryer unplugged check if there is continuity at the motor contacts M1 - M2. If they are closed - replace the motor.
The combination of this two things may be the reason for the problem you have.
Please, post the results.
Simon.
