target
#1 Posted : Saturday, March 14, 2009 9:06:43 PM(UTC)
target
all worked well for 4 years
fresh food side was at 20 degrees, on same setting for 4 years , turned it down to 1 and it went to 32 degrees.
how do i check the damper door assembly and the thermister/thermostat,
trying to find trouble shooting procedures to follow for symptoms.
would like also to check main board first...to make sure it's ok...
light switch is ok damper door is opening and closing ok
fan motor operation seems to be intermintent.
what is the most common item to be replaced on this model
have tried to find a repair and trouble shooting guide..
but none seems to be available... it must be on the national
security list of protected items,....... by ge
thanks
target
target
#2 Posted : Monday, March 16, 2009 10:15:45 AM(UTC)
target
so far no help; how long does it take for replys
