Drum will move but will not heat... what happened was i dried my ummm uhhh bra... and the wire some how came out and went into one of the holes in the back of the drum... we heard a squeak and the lights flickered.... it only happened within a few seconds... tinking that caused the fuse to blow.
Our Manual says that if 1 of the 2 fuses blow that there will be no heat... I can only find one fuse... we bypassed it and still no heat, so where is the other fuse?
THIS FORUM IS DEAD!!!!!!! |
