jeffamis
#1 Posted : 13 years ago
jeffamis
How do you replace the tub front and rear as well as the drum.
#2 Posted : 13 years ago
What is the original problem?
Replacing all of the parts you mentioned will cost you over a thousand dollars. A new machine will cost much less.
jeffamis
#3 Posted : 13 years ago
jeffamis
Thank-you for your reply about replacing front and rear tub and drum. Replacing the washer would be cheaper that buying all these parts. They are under warranty so there is no cost for parts. So how do I replace them?
#4 Posted : 13 years ago
Here is the Service manual for your washer. In order to download it you have to register on that web site first.
