Trb
trbandy
#1 Posted : Saturday, March 14, 2009 3:30:13 PM(UTC)
trbandy
Got a new thermal cut-off kit and replaced thermal cut-off. I did not install new thermostat supplied with new thermal cut-off because I can't tell from the schematic (picture) exactly how and where the wires go. If I do just as schematic shows I will have one extra wire from the harness not hooked up and one terminal on thermostat not hooked up and the wires will be connected to bottom terminal only of thermastat. I need a final scematic showing where all wires attach before I istall new thermostat. I have 2 wires coming from the harness and not sure from the instructions exactly which wires go where. Wondering if there is a new schematic or picture showing where all wiring goes and if all terminals on the new thermostat have wires going to them?
#2 Posted : Saturday, March 14, 2009 4:03:35 PM(UTC)
If you bought the thermal cutout kit AP3094244, it has instructions how to hook up the high limit thermal cutoff and the thermal fuse
Trb (Dryer Repair)
by trbandy 3/13/2009 4:42:05 PM(UTC)
amana trbl (Oven Repair (including Ranges and Cooktops))
by amanascott 12/29/2007 11:40:25 AM(UTC)
