How do you remove the outer door to gain access to soap dispenser for removal and replacement?
Here is the parts breakdown. Here is a manual which I think is a close match to yours. http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=234If your unit had the rinse aid sensor. Cut the connectors off those wires and then tape them up so they cannot short to each other or anything else. They discontinued this feature as it caused more problems than it was worth. |
THIS FORUM IS DEAD!!!!!!! |
