Purchased 09/2010- Heater Element Replaced ( Fried). Upon Replacement - The Clean Light blinks 7 times then pauses then 7times again & Again.When Selecting Control Panel Options - all the selection light BUT when you select the start Button _ Comes On Then Goes Off- NO Operation of diswaher. The Only operable selection is the Cancel/Drain -Two minutes then goes off.
Problem Due To ??
ControlPanel R Main Control Board
Will Give It A Shot
Many Thanks -
Originally Posted by: dneus ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Will Give It A Shot
Many Thanks - I should have asked this question upfront- What would be the cause of the heating element to short out. Just Wondering
Good question!
It can be anything from poor quality to excessive current.
Many Thanks - Had Ckd @ Is Closed - Which I think -means that is not the problem. - A Faulty Keypad @ r Main Control Board .?
Yes, the high limit thermostat passed the test, so the control board is the next. Make sure all wires are good. - The control board Part number: AP4566308
