eddevlin
#1 Posted : Thursday, March 12, 2009 5:41:49 PM(UTC)
eddevlin
any suggestions?
I checked the power connections,breaker is ok ,put amp probe on breaker and only draws 20amps with a 40 amp breaker?
#2 Posted : Friday, March 13, 2009 5:39:05 PM(UTC)
Can you be more specific on the problem?
The normal amount of current drawn by this oven should be written on the name plate (where the model number is).
There suppose to be one or two more numbers after "S" in the model number.
eddevlin
#3 Posted : Friday, March 13, 2009 6:53:11 PM(UTC)
eddevlin
after (s) is 0
#4 Posted : Saturday, March 14, 2009 3:25:19 AM(UTC)
Just some info
https://www.servicematters.com/d...0Sheet%20-%204451879.pdf
Depending which elements are on and the line voltage you should be able to figure out approximately what the current draw should be.
Also as Gene said
What exactly is happening???
eddevlin
#5 Posted : Saturday, March 14, 2009 5:34:45 AM(UTC)
eddevlin
Originally Posted by: denman Go to Quoted Post
Just some info
when cooking in upper oven it blows the breaker sometimes after 15 min sometimes it may not, and or if i shut the door hard it may do the same , I think something is loose and causing a short ,What do you think?I even checked all the connections and all seem fine.
Thanks,
Ed
#6 Posted : Saturday, March 14, 2009 7:05:48 AM(UTC)
I assume this is only when the upper unit is on and heating.
I think you are right but finding it is going to be a pain.
If the above I assume is correct then I would concentrate on the wires that have power only when this unit is on.
You will have to do a slow and complete inspection of each wire's insulation.
Would also check the frame for signs of an arc.
If you hear an arc or smell ozone at the oven when it pops the breaker then you know you have an intermittent dead short somewhere.
Gene may have a much better feel for this than I do.
eddevlin
#7 Posted : Sunday, March 15, 2009 12:55:28 PM(UTC)
eddevlin
if it were the board in the upper oven ,how much would a new board cost?
Guest (5)
