This washer is 16 months old and will not spin. The washer is level, also removed the pump to make sure nothing is clogging it. It also stops before rinsing in normal wash cycle. Sometimes the lid lock will not unlatch.
Could be a faulty lid switch.
It will go thru a few cycles and stop just before the rinse spin cycle. It shows rinse but there are suds on the clothes. You hit the start button and it will finish the cycle. I will check the lid switch today. Thanks
