4 Pages«<234
Brunowren
#31 Posted : Friday, March 23, 2012 3:19:33 PM(UTC)
Brunowren
Thank You so much Gene !! :)
#32 Posted : Friday, March 23, 2012 3:21:16 PM(UTC)
Brunowren
#33 Posted : Wednesday, April 4, 2012 4:57:44 PM(UTC)
Brunowren
Well ordered the part on Sunday 4/1 came in Tues 4/3 WOW ... and I had a working oven Tuesday night :)...Thank you so much Gene, you saved me a ton of money and made me the Hero of the month !!! :D
Thank you so much again Sir!!! Your knowledge is a huge help, money saver, and time saver!!! Bless You!
#34 Posted : Tuesday, April 10, 2012 3:44:45 PM(UTC)
You are welcome Eric. Thank you for your good words and for the feedback.
Good luck with your range.
Jwillison
#35 Posted : Tuesday, May 15, 2012 5:24:20 PM(UTC)
Jwillison
Hi Gene,
Similar problem as above but I would just like to confirm before I buy the part. I have a whirlpool Super capacity 456 model #Sf368lepb2, when turned on it clicks twice but won't heat up. Range works just fine. I tested the electrical thingys on the gas valve. Middle to bottom shows 205 ohms, middle to top shows nothing 0 ohms. Does this mean I need a new gas valve? Thanks for your help
#36 Posted : Tuesday, May 15, 2012 5:31:31 PM(UTC)
Originally Posted by: Jwillison Go to Quoted Post
...Middle to bottom shows 205 ohms, middle to top shows nothing 0 ohms. Does this mean I need a new gas valve...
Yes. No doubt about it.
- The gas valve Part number: W10293048
Blickster
#37 Posted : Tuesday, September 24, 2013 11:30:41 AM(UTC)
Blickster
Gene or community, our gas Whirlpool GS773LXSSO oven won't light but the broiler works fine. Would this still be the spark module or is this issue something else?
Thanks for your input.
Brian
EMurphy
#38 Posted: : Saturday, May 21, 2016 7:26:40 PM(UTC)
EMurphy
Good Evening,
I have a Whirlpool Accubake SF362LXSS that will not light the bake or broil element. The stove top is working fine and there are no error codes showing on the display/control panel.
When I turn the oven on in bake mode there is no clicking/ignition or detectable smell of gas.
When I turn the oven on in broil mode there are 2 slow clicks (slower than when it was working), no ignition, and a slight smell of gas.
Any suggestions?
Thanks M...
Tmoore789
#39 Posted : Saturday, June 11, 2016 3:27:16 AM(UTC)
Tmoore789
I'm having the same issue. Is this dealt with on another thread?
Thnx! Model SF362LXST
Tmoore789
#40 Posted : Saturday, June 11, 2016 3:32:52 AM(UTC)
Tmoore789
Originally Posted by: EMurphy Go to Quoted Post
Good Evening,
Any suggestions?
Thanks M...
Model SF362LXST
Thnx!
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 4:36:10 AM(UTC)
4 Pages«<234
