tom12345
#1 Posted : Thursday, March 12, 2009 1:05:08 PM(UTC)
tom12345
My microwave's magnetron needs to be replaced. The magnetron is a Sanyo 2M219HB, and I was wondering if it can be replaced with a 2M219JB. The specs appear identical, with the only noticeable difference being that the plug is on the bottom instead of on the side. Does anyone know if it would work? Thanks!
#2 Posted : Thursday, March 12, 2009 3:17:59 PM(UTC)
I do not think they are interchangeable due to different configuration.
gene.
tom12345
#3 Posted : Thursday, March 12, 2009 9:23:37 PM(UTC)
tom12345
gene.
Hi Gene,
What configuration are you referring to exactly?
Tom
#4 Posted : Thursday, March 12, 2009 9:45:07 PM(UTC)
Configuration is the relationship between the mounting ears, the vents (airflow) and the filament leads. Manufacturers have designated letter codes for various configurations.
The configuration of the magnetron 2M219HB is "H" and the configuration of the magnetron 2M219JB is "J".
tom12345
#5 Posted : Thursday, March 12, 2009 9:59:33 PM(UTC)
tom12345
Thanks for the info. The two magnetrons appear identical in every way, except for the filament leads coming out of a different side. So if I installed it, it would fit perfectly except the filament leads would be pointing up instead of left. As long as the wires reach, it should work, right? Would you happen to know what the "B" represents?
Tom
Tom
#6 Posted : Friday, March 13, 2009 6:53:49 PM(UTC)
Tom,
What you said sounds right except that if the filament leads will point to a metal microwave parts or to the outer case within a short insufficient distance to them it can cause an electrical short due to high (4.1 KV) voltage. You have to make sure it is going to be safe to use the microwave.
tom12345
#7 Posted : Sunday, March 15, 2009 10:44:04 PM(UTC)
tom12345
Hi Gene,
I did some checking and I can install the substitute magnetron with the filament leads pointing down, and the closest object would be the transformer about 1.25 inches away. Would that be a safe distance?
Tom
#8 Posted : Monday, March 16, 2009 4:29:47 PM(UTC)
Probably yes.
Guest (5)
