My Ice maker is receiving water and making cubes. The dispencer on the outside freezer door is not working. The lights are on but no water or ice comes out when the push lever is engaged. Any suggestions?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The light does dim when lever is pressed. Also I notice the motor thats running in the back stops when the lever is pushed. I tried a new switch #72 and I tried a new front panel #93. Niether one did any difference. What is my next option? I will return these two items.
Originally Posted by: Jeff G. ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...The light does dim when lever is pressed. Also I notice the motor thats running in the back stops when the lever is pushed... These symptoms point to a bad main control board on the back of the refrigerator. - The main control board Part number: AP4436216
