AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag Performa having a few issues..Please Help!
Purchased my Maytag Performa in 2006, have never had any issues with it. Yesterday I noticed my clothes were still really wet after washing. After doing another load staying by machine I noticed during wash & rinse cycle the agitator sounds loose.Then during the spin cycles it does not get up to full spin speed and it agitates during entire spin. Any advice would be helpful, Thanks!
Hello . Here is the most likely problem with your performa, Part number: AP4009132
thrust bearing I have sent you an attachment to illustrate this thank you and good luck!
It also could be a bad snubber ring under the tranny dome. If it gets out of balance easy, or if you see white shavings under the tranny, that would confirm it.
I will check on both of these possibilities. Thanks so much!
Washer Repair
