aurelio
#1 Posted : Monday, March 19, 2012 6:19:36 PM(UTC)
aurelio
I have a dishwasher DW44ZW and suddenly it stop filling the tube with water, it hears that motor is working and even though I open it it still working, when i poor water inside and close the door it pumps all the water out and seems to work fine until all the water has pushed out in a matter of 1 minute or maybe less.
What would be your recommendation for fixing this situation
Thank you !!
Gary/APP Team
#2 Posted : Wednesday, March 21, 2012 11:34:55 AM(UTC)
mattt
Hello. You either have a stuck Part number: AP2802373
float switch or you have a bad water valve Part number: AP3783031
not letting the water in it is good to use cleaner Part number: AP4308827
to keep this from happening if the float switch is stuck thank you and good luck !
