stoveman
#1 Posted : Tuesday, March 20, 2012 2:15:16 PM(UTC)
stoveman
looked at electronics in the top back of unit, identified Spark:) module top right corner of stove. wanted to know is there anything else that may be broke.
Spark Module
Part Number: AP3031050
Made by Whirlpool
#2 Posted : Tuesday, March 20, 2012 8:02:47 PM(UTC)
You may want to verify 120 VAC to the range and the spark module before ordering any parts.
If you are sure that the spark module is the culprit and you would like to order it, I would recommend the spark module with the different part number which cost much less. Electrically this is the same part. The only difference is the size of terminals but the new wire terminals are included in the kit. You have to cut off the old wire terminals and crimp on the new terminals.
- The spark module Part number: AP4010034
stoveman
#3 Posted : Wednesday, March 21, 2012 5:41:55 AM(UTC)
stoveman
Thanks Gene for quick reply !! the lower priced replacement great price!
should have stated the working parts along with my post.
did verify 120 VAC to the range. clock works, oven ignites, light oven works.
of course the burners do not.I can lite the burners with lighter. ;] gas valve works. Gene so I will take from your response there is nothing else that would stop the clicking/ spark. thx again!!!
#4 Posted : Wednesday, March 21, 2012 11:36:49 AM(UTC)
