Kenmore Electric Range Model 790.9542 3301, about 8 years old.
The panel with clock display and buttons stopped working. Since it controls the oven, the oven isn't working either. The dials to control the glasstop burners still work and the burners all get hot right away, as normal.
Does the clock/timer $182 part replace all the button controls for the oven as well as the clock? Is this a logical fix to my problem? Is it worth it to fix an 8 year old range for almost $200?
I can check the connections with a Voltage/continuity tester, but I don't know where to test and I haven't taken it apart yet. I know how to check outlets, but that's about it!
Also, how do I tell what wattage my glasstop burners are? A new range had 1,500 and 3,000 watt burners for the single and dual elements, but I have no idea if that's the same or way better than my model.
Thank you for any help you can provide.
THIS FORUM IS DEAD!!!!!!! |
Ok, I tested my power cord on the range. It's a four prong plug like this one: http://content.abt.com/m..._Images/big_PT400-v2.jpgWhen I touch any two prongs, they all give a "beep" on my continuity tester, except for the left prong in the picture. Touching this left prong and any other prong and there's no beep. Does this mean my power cord is fried?
[COLOR="DarkRed"]Does this mean my power cord is fried?[/COLOR] No Remove the small cover at the back of the unit so you can get to the terminal strip. Now measure from the plug prongs to the terminal connectors. The round connector (earth ground) should have continuity to the units frame. The lower flat connector (Neutral) should have continuity to white (usually the center connector on the terminal strip. The 2 side connectors (L1 and L2) should have continuity to either red or black (usually outer connectors on the terminal strip. In your case the important one is the Neutral, see the following. http://www.applianceaid.com/pictures/220voltrange.JPGYou did not say if the lights work. If they do then the unit is getting 120 volts. |
