This is a brand new timer.
Richappy, Thanks For You Help. I Replaced The Timer And Still I Have The Same Problem.
Two possibilities here, either your new timer is not the exact one for your washer, or you have a bad wire on the timer connector. Carefully check and compare your old timer with the new one. There might be a difference.
