2 Pages<12
Andre Filipe
#11 Posted : 16 years ago
Andre Filipe
I got hold of my mom and she has confirmed that the original problem was in fact the water drainage (should have asked since day one, I know!)
Moving forward, now I hope they (AppliancePartsPros), will accept the motor back...I have to read their return policy.
So what's the game plan?
TechnicianBrian
#12 Posted : 16 years ago
TechnicianBrian
I will again ask, when you set it for a spin cycle, what happens? Is there water in it now? Does the motor make any noise when a cycle is selected? Have you checked the lid switch as it will prevent the motor from running (and pumping water) during the spin cycle. You said the tub overflows when you start a cycle. Is that with water already in the tub? Does it agitate?
I ask questions and I need answers in order to provide some assistance.
Andre Filipe
#13 Posted : 16 years ago
Andre Filipe
Again, nothing happens when I set it for spin, no noise, nothing;
Yes, there is water there now from last time;
How am I suppose to "check" the lid switch? I don't have a ohm meter...
besides the lid switch is behind the water tub on my machine.
It only fills with water when it's set for WASH without any water and I just try again and it continues to overflow (even with water on it) and no the tub does not agitate. Thanks.
TechnicianBrian
#14 Posted : 16 years ago
TechnicianBrian
If nothing happens when you set it for spin, then I am still leaning toward the lid switch. You can check and make sure it clicks when you open close the lid, but the only real way to check would be to do a resistance check using a multimeter. The second problem of overflowing water is still the pressure switch as it is what tells the timer to start agitating and shuts off the water at the desired level. Both could be checked with a multimeter and unfortunately, they are not easily accessible without removing some panels. That is the advice I have for you so if you decide to do it yourself, or get someone else to look at it, we are here to help.
Andre Filipe
#15 Posted : 16 years ago
Andre Filipe
I am usually really persistent but I have no more time and patience playing Mr.Technician, I need to have it fixed and move on...can you recommend anyone (reliable)? Thanks.
TechnicianBrian
#16 Posted : 16 years ago
TechnicianBrian
Not knowing what part of the world you are in, my suggestion would be to visit some place like Appliance Repair | Company Reviews & Ratings, Appliance Repair Articles, see some of the technicians in your area and see how they rate with their customers.
Andre Filipe
#17 Posted : 16 years ago
Andre Filipe
Hey Brian, I installed the old motor back just to check if it works. When I switch it to spin it still doesn't move BUT it makes this acute noise as if the cycle is "stuck" (just my perception) then I smell something burning from it...I guess that's a clear sign it's not working properly.
What can you say about it?
BTW, thanks for the website, I will check it out.
FYI, I am in Margate, FL.
TechnicianBrian
#18 Posted : 16 years ago
TechnicianBrian
If the sounds is coming from the motor, it sounds like it is either locked up, or unable to start and is tripping the overload thermostat on the motor. This is usually accompanied by a hot electrical smell. Several things can lock up a motor from the pump to the gear case or even a failed capacitor preventing the motor start winding from starting the motor. You can remove the motor from it's mount and set it on the ground with the wiring still connected and see if it will run then. If it does, then you must be dealing with a mechanical problem, but if it doesn't, then an electrical problem is what you are looking for. The motor not running would explain why it won't drain, but not why it keeps filling with water. A bad timer could cause both problems if the noise seems to come from the timer. Sounds like the problem you are having is not as cut and dried as many others we see. Complex or multiple failures can be tough to locate and that is where being able to see something first hand allows for a much better diagnosis by a professional. That would be my suggestion unless you want to keep looking.
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 10 months ago
Fan motor replacement manitowoc (Refrigerator & Freezer Repair)
by Guest 2 years ago
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 4 years ago
Samsung dv40j3000ew/a2 wont start after motor replacement (Dryer Repair)
by rev1id 4 years ago
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 6 years ago
Washer wont drain, after motor replacement (Washer Repair)
by rweltz 7 years ago
Dryer Motor Replacement - wiring (Dryer Repair)
by houkden1 7 years ago
PYG2300AWW Motor Replacement (Dryer Repair)
by headmotty 8 years ago
GE dryer Motor replacement (Dryer Repair)
by etshome 10 years ago
by Washington3 10 years ago
Found extra part during pump/motor replacement (Dishwasher Repair)
by msg1524 10 years ago
dispenser motor replacement (Refrigerator & Freezer Repair)
by pusser 11 years ago
LG drain motor replacement (Washer Repair)
by Kim KS 12 years ago
Kenmore Ultra Wash Motor Replacement - need Serivce manual (Dishwasher Repair)
by GlennFord 12 years ago
Auger Motor Replacement (Refrigerator & Freezer Repair)
by millhouse 12 years ago
2 Pages<12
