I have the stackable washer and dryer by frigidaire gallery. My dryer kept getting stuck on 20 minutes and now its stuck on 60 minutes. Everything else seems fine with it. Do i just need a timer? If so where do i get one and how is it installed??? Is it easy?
Thanks Erika
It sounds like you need a TIMER, Its not that bad of a job to change it, Remove the dryer top, Then the Front panel, swap the wires to the new one ane reassemble.:)
Thank you. Where can I order a new one?
