RafiJ
#1 Posted : Wednesday, November 21, 2007 7:30:06 AM(UTC)
RafiJ
Hi. There is something wrong with my toilet. Initially I didn't notice, but as of recently every now and then the toilet starts making sounds. When I flush it the sound goes away. Upon a little inspection I noticed that when I took the back cover off the toilet, water started filling up. As it reached the top the noise continued and the water kept running. Once I flushed, the water went down and the noise stopped as well for a few moments and then started running up again. What do I do? :( I have a feeling my water bill is going to run up like crazy just because the water in the toilet won't stop running. Please help!
Handy
#2 Posted : Monday, November 26, 2007 9:45:07 AM(UTC)
Handy
You should take the lid off your tank and then pull up on the arm with the ball on the end.See if it will stop the water.If it does bend the arm a little.
