espriggs
#1 Posted : Wednesday, March 11, 2009 5:16:53 AM(UTC)
espriggs
Looking for some help :) I have a GE frig which the Ice maker is no longer dispensing or crushing ice. I have replaced both the solenoid and the drive motor with no luck. As far as I can see these are the only two components to the dispenser. Does anyone have a suggestion on where to turn next?
woodchuckie
#2 Posted : Wednesday, March 11, 2009 5:31:12 AM(UTC)
woodchuckie
Does the motor turn the augur? Does the solenoid click when the switch is depressed. Can you turn the augur by hand?
espriggs
#3 Posted : Wednesday, March 11, 2009 6:02:44 AM(UTC)
espriggs
Yes the motor turns the auger and can be turned by hand. The solenoid also clicks and seems to be operating. By operating I mean that the arm/shaft lift correctly or at least seem to.
