Originally Posted by: jamessalvia  ...What I'm asking is the toe kick/base cover one item or two?... It depends on the model number. Gene.
Originally Posted by: Gene  It depends on the model number.
Gene. Gene the model is Bosch SHU43C02/17
James,
You can use the instructions posted by Phil_Phil on 12/09/2010
I have the same question cannot seem to access the drain pump on my SHE55C05UC. Toekick removal does not reveal the pump, what else do I need to remove. Do the wires/ or water feed hose need to be removed too?
Please explain if you have a solution Thanks
