mikkiblue143
#1 Posted : Sunday, March 11, 2012 10:42:50 AM(UTC)
mikkiblue143
I cannot figure out how the latch on the detergent cup and the lever that goes to the time connect. The cup wouldn't open so I took apart the door. the two levers had become disconnected from one another and the cup latch had swiveled around to a point that it was hitting a stop. I turned it back around but can't figure out how to reconnect the two. The spring is not damaged and I do not see any broken plastic.
#2 Posted : Friday, March 16, 2012 3:04:41 AM(UTC)
Replacement parts for General Electric GSD4000J00WW Dishwasher | AppliancePartsPros.com
If you click on the picture of a part often a new page will open with better views, also there may be a Q&A section that you may find useful.
Perhaps the info on GE's in the following will help.
http://www.applianceaid.com/dishwash.html
