Chopper5150
#1 Posted : Thursday, March 15, 2012 10:58:59 AM(UTC)
Chopper5150
My washer seems to run okay. It fills at the beginning of the wash cycle, but when it gets through the first spin and then goes to fill back up for the rinse, it barely trickles out.
I appreciate any help you can provide me with.
#2 Posted : Thursday, March 15, 2012 1:44:13 PM(UTC)
How it will fill up if you select cold water for wash?
Chopper5150
#3 Posted : Thursday, March 15, 2012 2:09:30 PM(UTC)
Chopper5150
Nice question. It does seem that the pressure for the cold water is less than half the pressure that it use to be and is much less than the hot water line.
#4 Posted : Thursday, March 15, 2012 2:27:25 PM(UTC)
Check the water pressure at the cold water outlet. If there is nothing wrong, replace the water inlet valve. If you need the correct part number for the water inlet valve, post the serial number of the washer.
Chopper5150
#5 Posted : Thursday, March 15, 2012 2:46:28 PM(UTC)
Chopper5150
I'll check it. Thanks for your help.
Markram
#6 Posted : Thursday, March 15, 2012 2:48:08 PM(UTC)
Markram
First check the cold water inlet valve screen located at the machine end of fill hose, it may be clogged. If it is clogged, clean it out well and then see if that works.
No need to replace the valve log if you don't need to.
This happens a lot on houses with well water.
Check both ends of fill hose... there may be a screen on faucet end also.
Chopper5150
#7 Posted : Friday, March 16, 2012 8:48:04 AM(UTC)
Chopper5150
Thanks for all the help. It was simply a clogged cold water inlet filter. You saved me a bunch of money for a repair.
THANKS !!
#8 Posted : Friday, March 16, 2012 12:32:08 PM(UTC)
You are welcome. I'm glad it's up and running.
Guest (8)
