burndout
#1 Posted : Saturday, November 24, 2007 12:13:07 PM(UTC)
burndout
i have a shelvador and have noticed when opening the freezer that there is a sizzling sound coming from the back, like water dripping on a hot piece of metal. also i turned out all the lights and found that there is a bright orange glowing peice of metal with water dripping on it. i can unplug the fridge and it slowly fades away. my question is that if this is an automatic defrost of damaged parts? again, the glowing metal is in the lower part of the freeze behind the louvering in the lefthand corner.. Thanks
-Jon
abbie
#2 Posted : Saturday, November 24, 2007 4:44:57 PM(UTC)
abbie
What you discribed is the defrosting cycle of the fridge, what happens is when the fridge is ready to defrost the timer shut,s the fridge off sending power to the heating element. This cycle normally last for 30 min,s. The refrigerator normal goes into a defrost cycle every 6 to 8 to 12 hours a day, depending on the timer use in the fridge. Some refrigerators have a electronic boards to do the same thing as a timer would do. So what you have just seen is a normal defrosting cycle.
burndout
#3 Posted : Sunday, November 25, 2007 8:05:38 PM(UTC)
burndout
thanks for the info. now i can sleep at night and not worry about waking up to boiling beer can bombs.
