pauleouellette
#1 Posted : Tuesday, March 10, 2009 12:37:59 PM(UTC)
pauleouellette
Drum turns but no heat .
Is there a sequence for troubleshooting the circuit?
Can it be checked from behind the control panel by selecting particular switch settings to determine if the heating element is good/bad or the thermostats are good/bad?
What other elements may be involved with the lack of heat?
#2 Posted : Wednesday, March 11, 2009 3:14:46 AM(UTC)
Replacement parts for FRG LER331DS0 | AppliancePartsPros.com
Here is a wiring diagram
http://ftp.electrolux-na.com/PD....pdf&model=LER331DS0
Does the drum light work?
Does the timer advance in Timed Dry mode?
Does the timer advance in Auto mode?
If timer advances in Auto mode then odds are high that the heating element is good as the timer gets power through the element in this mode
Here is your circuit path for the heating element when motor is running:
L2 , M2/M1 motor's centrifugal switch , HEATER , HIGH LIMIT THERMOSTAT , CONTROL THERMOSTAT , A/B timer contacts , L1
Guest (4)
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by liz777 1/6/2011 9:11:35 PM(UTC)
by kamputty 4/11/2010 8:40:39 PM(UTC)
by bseibes 8/28/2008 6:59:14 PM(UTC)
dryer does not heat up (Dryer Repair)
by tkeemm 2/27/2008 6:37:29 AM(UTC)
by dralonso 2/21/2008 10:52:52 AM(UTC)
