hrdrockmom
#1 Posted : Tuesday, March 13, 2012 12:30:05 PM(UTC)
hrdrockmom
when i start my dryer everything works but the igniter, so I replaced the igniter and it still will not glow, the dryer used to make a loud click when the igniter would glow, light the burner then click again when the burner lit but it does not make the click sound anymore.
ApplianceJunk
#2 Posted : Tuesday, March 13, 2012 3:25:18 PM(UTC)
ApplianceJunk
I would use a multimeter and check the thermal fuse for continuity.
hrdrockmom
#3 Posted : Wednesday, March 14, 2012 10:10:17 AM(UTC)
hrdrockmom
turns out that the thermal fuse was open, causing the problem. Thank you:)
Guest (4)
