I want to remove the hex screw and the space is tight for an adjustable wrench. I think a nonadustablew wrench would be easier to remove the screw to replace the ignitor. What size should I use?
You have posted on the Washer Forum. If you will repost on the Dryer Forum someone should be able to help you.
