2 Pages12>
jlboyd
#1 Posted : Monday, March 9, 2009 7:58:52 AM(UTC)
jlboyd
Food caught on fire, now the microwave acts as if there is not power, which there is. Other posts mention a flame sensor, I do not see that on the bill of materials associated with this model.
#2 Posted : Monday, March 9, 2009 6:18:55 PM(UTC)
Look for the wiring diagram behind the top grille or behind the control panel. Post it.
jlboyd
#3 Posted : Monday, March 9, 2009 6:58:38 PM(UTC)
jlboyd
Gene,
Thank you very much for the reply. I have the wiring diagram, technical specifications and bill of parts from the GE website and from AppliancePartsPros.com. What I don't know how to find is a functional description for which part my daughter's potato fire damaged.
I see several thermostats and microswitches listed, and have insufficient knowledge to determine which one needs to be replaced. My alternative is to purchase a new microwave and just replace it, but that seems wasteful given that a $10 part might do the trick.
Do you know which part needs to be replaced and if a moderately skilled mechanical guy could replace it?
Thanks,
Jesse
jlboyd
#4 Posted : Monday, March 9, 2009 7:17:15 PM(UTC)
jlboyd
Please find the attached diagram and descriptions. The descriptions are located here Replacement parts for GE JVM1871SH02 | AppliancePartsPros.com
Thanks,
jesse
File Attachment(s):
Microwave JVM1871SHO2 Parts List.pdf (81kb) downloaded 6 time(s).
#5 Posted : Tuesday, March 10, 2009 1:30:58 PM(UTC)
The information you posted is not really what I asked for. I need the Wiring diagram which is not published on-line. It must be supplied with the microwave.
jlboyd
#6 Posted: : Friday, March 13, 2009 8:24:13 PM(UTC)
jlboyd
For those of you keeping score at home, when your daughter (or other unsuspecting family member) starts a fire in this model microwave, the correct replacement part is Thermostat WB27X10810.
It can be replaced by removing the sheet metal exterior and 1 screw from the plastic molding. Had I done this before, it would have taken about an hour to dismount, disassemble, replace the part (very simple), reassemble and remount. Remounting was by far the hardest part. I am going to feel that in my lower back tomorrow morning.
Gene, thanks for trying to help. I am an engineer by training and thought this would be the correct temperature element given its physical location. Guessing was worth a $10 part given that I have no wiring diagram to use, although I would agree that it would have been helpful in understanding the control system.
Jesse
#7 Posted : Saturday, March 14, 2009 12:07:14 PM(UTC)
Jesse,
I'm glad you were able to fix it.
alexbest4u
#8 Posted : Monday, November 30, 2009 6:51:30 PM(UTC)
alexbest4u
Gene can you help my find the right sensor, please?
I had exactly the same scenario as above (food caught on fire and I heard the cutoff click followed by the power disconnect) except I got a different GE Microwave model:
GE Spacemaker XL1800
Model # JVM1850BH06
Serial # HL900721B
#9 Posted : Monday, November 30, 2009 8:21:47 PM(UTC)
Looks like the part needed for your microwave is the same as Jesse had replaced. It is the cavity thermostat and it's shown as #44 on the diagram.
- The cavity thermostat Part number: AP3792919
Utejohn98
#10 Posted : Thursday, September 20, 2012 7:07:19 PM(UTC)
Utejohn98
My wife burnt some popcorn and then boiled water to get rid of the smell. Then it quit working after about 10 minutes of boiling? Where do I go from here?
2 Pages12>
