iamracerexx
#1 Posted : Tuesday, March 6, 2012 6:16:35 AM(UTC)
iamracerexx
Hi, I've checked the water inlet valve and the float valve and both are good. However, the water inlet valve does not get any voltage. I tested it two ways. First by removing the two wire to it and used a lamp cord with connectors to see if water comes out. I also tested it with my meter attached and started the washer and no voltage ever reached the valve? I am not sure where to go from here?
Thanks in advance,
iamracerexx
#2 Posted : Friday, March 9, 2012 5:48:20 AM(UTC)
iamracerexx
Anyone have insight on the problem I am have having with my machine?
iamracerexx
#3 Posted : Saturday, March 10, 2012 3:42:37 AM(UTC)
iamracerexx
I figured it out. I finally pulled the mother board off an inspected all of the soldered trails on the back-side. One trail was broken. I repaired it very carefully and the machine is now working properly.
