a/c guy
#1 Posted : Friday, November 23, 2007 7:47:42 AM(UTC)
a/c guy
changed sensors in freezer section & 'frige section, changed main board, all at recommondations by other blogs, still coil behind produce bin still ices up completely every 2 weeks. i see a sensor mounted under the coil after I defrost it, can this be the problem?? HELP
jdappl07
#2 Posted : Saturday, November 24, 2007 7:08:54 AM(UTC)
jdappl07
did you check the heater at the bottom of the coil (evaporator)
jumptrout51
#3 Posted : Sunday, November 25, 2007 5:56:28 AM(UTC)
jumptrout51
Groups: Expert
Check continuity on the heater leads. Pay attention to the wires on the leads. I have seen them get loose and come off.
abbie
#4 Posted : Sunday, November 25, 2007 7:22:36 AM(UTC)
abbie
let,s start over, you say the coils are iceing up, does this mean there ice or snow? if there ice this may not be a defrosting problem it may be a drain problem ,on the model # i did not see a drain trough heater make sure there is no service flashes on this problem . Make sure the drain is completely clear. Then we go from there.
Help need diagnosing evap coil freeze up (Refrigerator & Freezer Repair)
by Mudbone 5/20/2010 9:39:54 AM(UTC)
