unsure of model number. dryer is not getting hot, it takes several cycles to dry clothes. looks as if some of the coils are working but not all. do i need a new element or thermostat? (electric dryer) thank you
What is the model number?
Long drying times = Restricted Air Flow
Clean the dryer vent and the lint from around the blower wheel inside the dryer.
If part of the element is heating, you could have a broken element. Before you replace the element, make sure the vent is clear. Tom ApplianceEducator.com
I will double check the vent before i order a new element. Thank You for the responses were very helpful.
