Mph08si
#1 Posted : Monday, March 5, 2012 5:11:33 PM(UTC)
Mph08si
Hi. I'm new to this forum and appliance repair in general. I have a direct drive washer that spins slow. Very slow. Could someone explain to me how and what parts are involved with making a washer spin so I can try to fix it. I don't want to guess and keep buying parts for it. Any help would be great. Thanks all. Matt
Simon / APP Team
#2 Posted : Monday, March 5, 2012 7:37:44 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Matt.
I need a complete washer model number. But generally If the water is drain out completely before spin cycle starts you should be replacing the clutch. With the full model number I'll get you the part number.
Mph08si
#3 Posted : Tuesday, March 6, 2012 2:02:46 PM(UTC)
Mph08si
Thank you for the response. The model number is LSW9750PW3.
Simon / APP Team
#4 Posted : Wednesday, March 7, 2012 11:30:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First check if you can manually spin the tub. If it's spins easily then check the drive block.
If not - replace the clutch.
The clutch Part number: AP3094537
Mph08si
#5 Posted : Wednesday, March 7, 2012 6:02:23 PM(UTC)
Mph08si
Thanks for all the help. I replaced the clutch and it works great. Thanks again
Simon / APP Team
#6 Posted : Wednesday, March 7, 2012 6:06:43 PM(UTC)
Simon / APP Team
Groups: APP Team
My pleasure.
enjoydoing
#7 Posted : Monday, March 26, 2012 11:33:25 AM(UTC)
enjoydoing
Hi. I have a whirlpool washer LSQ9010PWS3 that spins normal in the first two or three years, recently, I found the clothing is still wet after the full rinse cycle. I thought it is bad coupler based on the forum, so, I disassembled and found the coupler is good. Then, I follow the repair forum, to take a part the clutch, etc, found it is still good, at least, I don't see any worn out, on clutch, springs, etc. Could someone explain to me how and what parts I should take a part or check further before I buy parts randomly, greatly appreciated for your help, Thanks and have a wonderful day. David
Simon / APP Team
#8 Posted : Tuesday, March 27, 2012 9:58:26 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the washer is draining good and drive block and the spin tube are good, than most likely the problem is bad clutch.
Check the drive block and the spin tube joint at the top under the agitator.
Her are the breakdown diagrams and Replacement parts for Whirlpool LSQ9010PW3 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Guest (4)
Whirlpool washer spins slowly and noisily (Washer Repair)
by chuckledog 3/3/2017 6:26:54 AM(UTC)
Whirlpool washer spins slow (Washer Repair)
by schwindt14 2/3/2017 8:55:00 AM(UTC)
Whirlpool washer spins slow often after many rebalances (Washer Repair)
by sg23 2/1/2013 6:33:40 AM(UTC)
Whirlpool Washer spins SLOWLY even after putting in new clutch (Washer Repair)
by babaasheri 1/15/2013 5:24:11 PM(UTC)
