greenfield
#1 Posted : Sunday, March 8, 2009 10:50:56 AM(UTC)
greenfield
When the lid is lifted it no longer stops before hitting aginst the control panel.
I suspect the torsion rod but I cannot see where it is broken.
Is there suposed to be a stop that keeps the lid from going all the way back?
kayakcrzy
#2 Posted : Sunday, March 8, 2009 4:27:25 PM(UTC)
kayakcrzy
It sounds like the lid switch is the problem. It will eventually break and the product will not spin. Tom
greenfield
#3 Posted : Sunday, March 8, 2009 4:58:39 PM(UTC)
greenfield
I guess I did not explain the problem quite clearly.
The tub stops spinning fine. I am talking about the lid actually hitting aginst the control panel when it is opeaned.
#4 Posted : Monday, March 9, 2009 3:55:51 AM(UTC)
Model Search
Here is a service manual
https://secured.whirlpoo.../Maytag_Atlantis_III.pdf
Sounds like something has broken in the lid hinge or torsion bar.
The manual shoul help you locate and repair it.
