bobalou07
#1 Posted : Thursday, February 9, 2012 1:05:41 PM(UTC)
bobalou07
have maytag washer that needs tub bearing. would like to do it myself,after watching you tube i think i can do it. question. will i need spanner nut wrench? any last tips befor i get my feet wet. also where is the best place to order parts? thanks bobalou07:)
Gary/APP Team
#2 Posted : Tuesday, March 6, 2012 1:19:02 PM(UTC)
mattt
Hello. The best advice that I can give on this adventure, would be to try and locate a technician that has the tool and try to borrow it , I have heard of folks using a cold chisel to get them off, that seems a little risky, you could soak it with WD-40 the real problem would be getting the new one tight enough with out doing damage to it , or the threads on the transmission here is the part AP3538707'); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP3538707" target="_blank">Part number: AP3538707
AP3538707" target="_blank"> AP3538707" border="0" alt="Part number: AP3538707" title="Part number: AP3538707">
AP3538707">
we have them in stock thank you and good luck !
bobalou07
#3 Posted : Friday, March 9, 2012 4:17:59 PM(UTC)
bobalou07
i know and old dude that might have one,will get on it. thanks bobalou.
