renier company
#1 Posted : Friday, October 5, 2007 10:06:12 AM(UTC)
renier company
The temp guage says that the oven has reached temp long before it has actually reached temp
Pegi
#2 Posted : Friday, October 5, 2007 1:24:24 PM(UTC)
Pegi
How long are you letting it pre-heat, let it heat at least 20 minutes, over 30 is better then see if it is at the correct temp or not...
renier company
#3 Posted : Friday, October 5, 2007 2:36:26 PM(UTC)
renier company
The oven will not reach temp even after an hour. The temp gauge tells the oven to stop heating because it reads a higher number than the oven really is.
leon
#4 Posted : Wednesday, October 31, 2007 7:43:46 PM(UTC)
leon
I had the same problem, when I replaced capacitors c9 & c10 in the control it corrected it.
leon
s_temp
#5 Posted : Saturday, March 7, 2009 1:25:34 PM(UTC)
s_temp
Leon is 100% right! Went to Radioshack. . . bought the capacitors (4.7uF 35 V) and replaced c9 and c10. . . THANK YOU, LEON. Would love to know how you figured that out.
Steve
